Data Domain BoostFS with HyperScale X?
  • June 21, 2021
  • 7 replies
  • 570 views
Is it possible to install the BoostFS library on a HyperScale X Media Agent, and if so is it supported?
I’m looking to write a additional backup copy to storage outside of the appliance and hope I can do it in a deduplicated manner rather than having to send a full copy to the data domain.  The topic of BoostFS is discussed on https://documentation.commvault.com/commvault/v11/article?p=9404.htm#o132281, but nothing specific to HyperScale X and BoostFS at https://documentation.commvault.com/commvault/v11/article?p=128105.htm.
Best answer by Mike Struening
Got a reply from the Product Manager himself:
Not directly no. The only external storage we support writing directly to with HS or HSX is Cloud targets (and limited to the same size as the HS/HSX Storage)
Hey @Skarra !
Thanks for the question.  No, we don't support attaching additional disk libraries to HyperScale Nodes (1.5 or X)
  • June 23, 2021
Thank you Mike for the clarification.  I assume that’s a No to all disk library types, PBBA and NAS.
I’ll confirm that to be certain.
  • September 1, 2021
Hi Mike - can you provide a confirmation for HyperScale X (appliance or reference architecture) writing to an external PBBA/NAS?  Thanks.
I’ll find out!
  • September 1, 2021
Thank you for comfirming.
