HyperScale-X and NetApp NAS Library
  • Feb 14, 2024 9:01 AM UTC
  • 129 views
Hello
We plan to use NetApp CSeries QLC as a Disk Library for high performance restore with HyperScale-X
Do we need additional Media Agent to have the primary copy directly written to the NetApp Array then pushed to tape from the HyperScale-X nodes ?
Best answer by R Anwar
Hi @MDE
It’s better to have a separate MA here and use HSX to copy the data to Tape Library.
R Anwar
  • Feb 14, 2024 10:05 AM UTC
Hi @MDE
  • Feb 14, 2024 2:50 PM UTC
Thanks for the quick reply
Is it better to have it separated or just plain not supported to have the HSX node use another primary disk (DDB limit for example)
We like the Appliances / certified OS / Software but will need QLC Flash for performance. ?
