Hyperscale-X node deployment: Inappropriate ioctl for device - AddOn comments
  • Aug 15, 2023 11:07 AM UTC
  • 170 views
wanted to add comments to this thread -
we too ran into this issue … HSX image install failure , after MANY hours you get this in the install console --
  • Aug 15, 2023 11:11 AM UTC
Our Resolution ….  Pull Down the HSX install image and DO NOT MOVE THE IMAGE FILE …. start the ISO image install process from the location where you first pulled down the iso. …. if you move the file the file gets corrupted.. run thru the checksum steps.. after we started the install from our original download location ( we did not move the file ) - all of our installs were successful -- each HSX took about 1 hour to image -- LINUX version of HSX --
