Missing permission for run CVDiskPerf
  • Mar 17, 2024 3:43 PM UTC
  • 152 views
Forum|alt.badge.img+5
Hi
I am trying to run CVDiskPerf on a HyperScale X ver. 3 node that have ransomeware protection enabled.
I am logged in as root, but when I am trying to execute the cvdiskperf command, I am getting “
-bash: ./CVDiskPerf: Permission denied”.
I have used this command on a HyperScale X ver. 2 cluster without any permission issues when I am logged in as the root user.
Does any one know how to solve this problem=
Emils
  • Mar 17, 2024 11:49 PM UTC
Hi @Anders Trier Rasmussen
Thanks for reaching out, this is expected and by design when ransomware protection is enabled.
You should be able to reach the same outcome using the “Validate Mount Path” feature.
Thank you
Hi Emils
Thanks for your answer.
Anders
