Adding OneDrive Users to CloudApp subclient fails after Discovering Successfully.
  • May 19, 2021
  • 125 views
VinR
Novice
I’m trying to configure backups for our users migrated to OneDrive for Business.
When trying to add OneDrive Users to CloudApp subclient, I can discover them manually but selecting a user and then clicking OK does not add them to the Content list.
https://documentation.commvault.com/commvault/v11_sp20/article?p=30230.htm
Best answer by Chris
VinR,
It looks like the docs are missing a step here.  Please try again but this time click either the column and row for the user on the right that says subclient and/or if you multiselect click the down arrow at the bottom where it says Change all selected accounts to: then click OK.
Chris
  • May 19, 2021
VinR,
Forum|alt.badge.img+2
  • May 19, 2021
As Chris said it looks like an empty cell but you can click on it to enable a drop down where you can select a subclient for it to be associated with.
VinR
Novice
  • May 19, 2021
Thanks Chris. I used the Command Center and it worked and I was able to get a test OD user in. Testing the backup now. I’ll check your suggestion also.
Vin
Tagging @Seema Ghai to check our docs.
  • May 19, 2021
Thanks for bringing this to our attention. We will update the documentation to include the missing information. @Kriti Sweta
