HPE Aux copy isseus
  • 1 March 2024
  • 12 views
Badge +5
[Catalyst\53X0E7_10.20.2021_13.11\CV_MAGNETIC\V_298] [-1910 OSCLT_ERR_OBJECT_KEY_NOT_FOUND] getting following error.
This is a very generic error sent by HP. It can mean that the volume folder does not exist or that there is a connection issue to Catalyst. Please check existence of this v folder from HP side and the connectivity between the MA running the aux copy and the Catalyst.
Userlevel 5
Badge +14
Hello @backing up active directory
Also, what kind of Job is this? Backup, Aux Copy, or Restore? If you View > Logs from the Job, do you see any other errors being reported in CVD.log on the MediaAgent?
Thank you,
Collin
