has anyone ever tried to send the library description in a library offline alert?
This is no problem in client or subclient alerts, but I don't see any way to send this with libraries as well.
The Notification Tokens don't seem to have a selection for this either
Hello @Sven Heusohn
Can you clarify what you mean by Library Description? The alert should show the name of the library encountering the issue.
Thank you,
Collin
Hello @Collin Harper
I’m talking about the actual Description Field on the Library (Libraries → “Lib Name” → Properties → Description on the Bottom of the Window
The desciption tokens are only available for either clients, subclients, jobs and alert conditions detected.
For libraries you have only a Library Name token available.
If you have a need for additional tokens I would advise you to raise a CMR, this might not be a short term change though, that depends on existing and future priorities within the development department.
