I am planning an infrastructure refresh where I need to retire an existing MediaAgent and migrate its FC-attached tape library to a newly deployed Commvault HyperScale Edge node.
My main focus is ensuring data path consistency, avoiding any library deconfiguration, and maintaining restore capabilities. The planned high-level workflow is:
Re-zone the FC tape library to the new HyperScale Edge node.
Validate OS-level hardware detection on the Edge node.
Use Expert Storage Configuration to perform Exhaustive Detection, adding the new Edge MA to the library while keeping the existing configuration intact.
Execute "Change Data Path" on the relevant Storage Policy Copies to point to the new Edge MA.
Perform standard MediaAgent Retirement on the old node.
I am looking for technical validation of this workflow. Specifically:
Are there any HyperScale Edge-specific prerequisites or limitations regarding direct-attached or FC-switched tape libraries?
What are the known issues regarding existing Drive Pools/Master Drive Pools during the Data Path change in this specific scenario?
Are there any specific CLI commands recommended for verifying the SCSI paths natively on the HyperScale Edge Linux OS before triggering the Exhaustive Detection?
I am looking for validated field experience and references to official Commvault documentation.
