Network error port 8400*8402
  • April 27, 2022
  • 8 replies
  • 4099 views
Failed to start phase [Backup] on [BPOBRTIAS136] due to network error [Remote system [BPOBRTIAS136*BPOBRTIAS136*8400*8402]. Communications Service returned error when executing remote command [cdrcontrol.exe] arguments [-j 4672 -a 84 -r 110 -n 2:231 -jt 4672:2:1:0:59267 -f 0 -q 1 -s 0 ].]. Will attempt to restart. Please check if this product's services are running on the remote host.
Source: BPOTSMIAS288, Process: JobManager
Network Problem
Best answer by Jose Ricardo
Mike thanks for the feedback, really the Continuous Data Replication application was not installed on the server with end 136, I did the installation and when I ran the backup it appeared this msg. in the alerts console
Decrease in Data size by 10 percent
Forum|alt.badge.img+18
  • April 27, 2022
Good morning.  Can you please verify if Commvault services are started on BPOBRTIAS136?
  • April 27, 2022
Obrigado pelo retorno @Orazan ,
Sim,
[root@BPOBRTIAS136 ~]# commvault -all status
--------------------------------- Instance001 ---------------------------------
[ General ]
 Version = 11.24.34
 Media Revision = 952
 CommServe Host Name = BPOTSMIAS288
 CommServe Client Name = BPOTSMIAS288
 Home Directory = /opt/commvault/Base
 Log Directory = /var/log/commvault/Log_Files
 Core Directory = /opt/commvault
 Temp Directory = /opt/commvault/Base/Temp
 Platform Type = 6
 Cvd Port Number = 8400
[ Package ]
 1002/CVGxBase = File System Core
 1101/CVGxIDA = File System
 1301/CVGxMA = MediaAgent
[ Physical Machine/Cluster Groups ]
 Display Name = BPOBRTIAS136
  - Client Hostname = BPOBRTIAS136
  - Job Results Directory = /opt/commvault/iDataAgent/jobResults
  - Index Cache Directory = /opt/commvault/MediaAgent/IndexCache
  • April 28, 2022
would anyone get help? please
Jose Ricardo
@Jose Ricardo , this looks like a communications error.
Can you share what you see in CVD.log?
  • April 28, 2022
yes I can share, but the moderator only allows 30,000 lines,
25729 1c30 04/27 22:33:11 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
* Received remote execute request for process cdrcontrol.
* Could not find this executable: /opt/commvault/iDataAgent/cdrcontrol.
25729 1c32 04/27 22:33:11 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 22:34:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [103.93 ms], Avg Wait Time [61.00 us]
25729 64cc 04/27 22:34:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [213.00 us], Avg Wait Time [71.00 us]
25729 64cc 04/27 22:34:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [369.33 us], Avg Wait Time [51.67 us]
25729 64cc 04/27 22:34:59 ### TPool [N/A]. Ser# [1] Tot [5], Pend [0], Comp [5], Max Par [5], Avg Work Time [823.60 us], Avg Wait Time [205.00 us]
25729 1eb1 04/27 22:38:12 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 1eb3 04/27 22:38:13 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 1f54 04/27 22:39:59 --- IndexCacheMaintenance() - Index cache for client [BPOBRTIAS136] is using 1 MB. Location is [/opt/commvault/MediaAgent/IndexCache].
25729 64cc 04/27 22:39:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [106.51 ms], Avg Wait Time [47.00 us]
25729 64cc 04/27 22:39:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [205.00 us], Avg Wait Time [39.00 us]
25729 64cc 04/27 22:39:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [303.00 us], Avg Wait Time [141.33 us]
25729 64cc 04/27 22:39:59 ### TPool [N/A]. Ser# [1] Tot [5], Pend [0], Comp [5], Max Par [5], Avg Work Time [56.19 ms], Avg Wait Time [156.20 us]
25729 1f58 04/27 22:39:59 --- CCVDSpaceCheck::CleanupIdleEventConnections() - Invoking CleanUp Idle Event Connections.
25729 1f58 04/27 22:39:59 ### periodicallyCleanUpIdleEventConnections() - CleanUpIdleEventConnections  started
25729 21ed 04/27 22:43:13 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 21ee 04/27 22:43:13 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 21ff 04/27 22:43:15 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=BPOTSMIAS084. Remote port request error.
* Could not get the registered port for service FlrRepPairSvc. Error:0x80070306:{CCvNetwork::LookupRegisteredPorts(4700)} + {CCvNetwork::LookupRegisteredPorts_Common(4825)} + {CCvNetwork::LookupRegisteredPorts_Common(4765)} + {CCvNetwork::LookupRegisteredPorts_Local(4459)} + {CSessionConnectionSocket::LookupPort(1093)/W32.774.(One or more errors occurred while processing the request. (ERROR_ERRORS_ENCOUNTERED.774))-No port looked up for service FlrRepPairSvc}
25729 64cc 04/27 22:44:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [104.85 ms], Avg Wait Time [58.00 us]
25729 64cc 04/27 22:44:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [292.00 us], Avg Wait Time [51.00 us]
25729 64cc 04/27 22:44:59 ### TPool [N/A]. Ser# [0] Tot [5], Pend [0], Comp [5], Max Par [1], Avg Work Time [3.49 ms], Avg Wait Time [56.40 us]
25729 64cc 04/27 22:44:59 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [4], Avg Work Time [697.25 us], Avg Wait Time [140.50 us]
25729 2470 04/27 22:48:14 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 2471 04/27 22:48:14 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 22:49:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [105.49 ms], Avg Wait Time [47.00 us]
25729 64cc 04/27 22:49:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [272.00 us], Avg Wait Time [42.00 us]
25729 64cc 04/27 22:49:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [278.67 us], Avg Wait Time [43.67 us]
25729 64cc 04/27 22:49:59 ### TPool [N/A]. Ser# [1] Tot [6], Pend [0], Comp [6], Max Par [6], Avg Work Time [796.17 us], Avg Wait Time [140.67 us]
25729 26f2 04/27 22:53:14 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 26f3 04/27 22:53:14 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 22:54:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [106.08 ms], Avg Wait Time [42.00 us]
25729 64cc 04/27 22:54:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [254.00 us], Avg Wait Time [47.00 us]
25729 64cc 04/27 22:54:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [346.33 us], Avg Wait Time [46.67 us]
25729 64cc 04/27 22:54:59 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [4], Avg Work Time [686.25 us], Avg Wait Time [94.00 us]
25729 29d6 04/27 22:58:15 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 29d7 04/27 22:58:15 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 22:59:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [104.07 ms], Avg Wait Time [57.00 us]
25729 64cc 04/27 22:59:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [252.00 us], Avg Wait Time [54.00 us]
25729 64cc 04/27 22:59:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [341.00 us], Avg Wait Time [48.00 us]
25729 64cc 04/27 22:59:59 ### TPool [N/A]. Ser# [1] Tot [5], Pend [1], Comp [4], Max Par [5], Avg Work Time [913.75 us], Avg Wait Time [138.50 us]
25729 2a6b 04/27 22:59:59 --- CCVDSpaceCheck::CleanupIdleEventConnections() - Invoking CleanUp Idle Event Connections.
25729 2a6b 04/27 22:59:59 ### periodicallyCleanUpIdleEventConnections() - CleanUpIdleEventConnections  started
25729 2a68 04/27 22:59:59 --- IndexCacheMaintenance() - Index cache for client [BPOBRTIAS136] is using 1 MB. Location is [/opt/commvault/MediaAgent/IndexCache].
25729 2c6a 04/27 23:03:15 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 2c6b 04/27 23:03:15 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 2cda 04/27 23:04:19 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=BPOTSMIAS084. Remote port request error.
25729 64cc 04/27 23:04:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [104.47 ms], Avg Wait Time [44.00 us]
25729 64cc 04/27 23:04:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [287.00 us], Avg Wait Time [56.00 us]
25729 64cc 04/27 23:04:59 ### TPool [N/A]. Ser# [0] Tot [5], Pend [0], Comp [5], Max Par [1], Avg Work Time [3.55 ms], Avg Wait Time [56.60 us]
25729 64cc 04/27 23:04:59 ### TPool [N/A]. Ser# [1] Tot [6], Pend [0], Comp [6], Max Par [5], Avg Work Time [44.83 ms], Avg Wait Time [129.33 us]
25729 2ef9 04/27 23:08:17 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 2efb 04/27 23:08:18 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 23:09:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [142.58 ms], Avg Wait Time [41.00 us]
25729 64cc 04/27 23:09:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [221.00 us], Avg Wait Time [41.00 us]
25729 64cc 04/27 23:09:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [345.67 us], Avg Wait Time [43.67 us]
25729 64cc 04/27 23:09:59 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [4], Avg Work Time [793.75 us], Avg Wait Time [145.50 us]
25729 31df 04/27 23:13:18 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 31e1 04/27 23:13:20 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 23:14:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [105.32 ms], Avg Wait Time [53.00 us]
25729 64cc 04/27 23:14:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [259.00 us], Avg Wait Time [47.00 us]
25729 64cc 04/27 23:14:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [364.00 us], Avg Wait Time [48.67 us]
25729 64cc 04/27 23:14:59 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [4], Avg Work Time [664.50 us], Avg Wait Time [131.75 us]
25729 3483 04/27 23:18:20 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 3484 04/27 23:18:20 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 3517 04/27 23:19:59 --- additionalSettingsRefresh() - Cleaning temporary key.
25729 64cc 04/27 23:19:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [106.74 ms], Avg Wait Time [85.00 us]
25729 64cc 04/27 23:19:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [252.00 us], Avg Wait Time [79.00 us]
25729 64cc 04/27 23:19:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [329.33 us], Avg Wait Time [48.33 us]
25729 64cc 04/27 23:19:59 ### TPool [N/A]. Ser# [1] Tot [9], Pend [3], Comp [6], Max Par [9], Avg Work Time [1.93 ms], Avg Wait Time [488.50 us]
25729 3518 04/27 23:19:59 --- CCVDSpaceCheck::CleanupIdleEventConnections() - Invoking CleanUp Idle Event Connections.
25729 3518 04/27 23:19:59 ### periodicallyCleanUpIdleEventConnections() - CleanUpIdleEventConnections  started
25729 3511 04/27 23:20:00 --- IndexCacheMaintenance() - Index cache for client [BPOBRTIAS136] is using 1 MB. Location is [/opt/commvault/MediaAgent/IndexCache].
25729 3709 04/27 23:23:21 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 370a 04/27 23:23:21 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 3777 04/27 23:24:23 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=BPOTSMIAS084. Remote port request error.
25729 64cc 04/27 23:24:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [105.20 ms], Avg Wait Time [45.00 us]
25729 64cc 04/27 23:24:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [234.00 us], Avg Wait Time [42.00 us]
25729 64cc 04/27 23:24:59 ### TPool [N/A]. Ser# [0] Tot [5], Pend [0], Comp [5], Max Par [1], Avg Work Time [3.54 ms], Avg Wait Time [66.20 us]
25729 64cc 04/27 23:24:59 ### TPool [N/A]. Ser# [1] Tot [7], Pend [0], Comp [7], Max Par [4], Avg Work Time [260.01 ms], Avg Wait Time [63.00 us]
25729 39fd 04/27 23:28:21 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 39fe 04/27 23:28:21 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 23:29:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [104.35 ms], Avg Wait Time [62.00 us]
25729 64cc 04/27 23:29:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [239.00 us], Avg Wait Time [43.00 us]
25729 64cc 04/27 23:29:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [313.67 us], Avg Wait Time [61.67 us]
25729 64cc 04/27 23:29:59 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [4], Avg Work Time [769.25 us], Avg Wait Time [785.25 us]
25729 3c80 04/27 23:33:22 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 3c81 04/27 23:33:23 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 23:34:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [104.71 ms], Avg Wait Time [43.00 us]
25729 64cc 04/27 23:34:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [291.00 us], Avg Wait Time [48.00 us]
25729 64cc 04/27 23:34:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [395.33 us], Avg Wait Time [59.67 us]
25729 3efb 04/27 23:38:24 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 3efc 04/27 23:38:25 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 3f86 04/27 23:39:59 --- CCVDSpaceCheck::CleanupIdleEventConnections() - Invoking CleanUp Idle Event Connections.
25729 3f86 04/27 23:39:59 ### periodicallyCleanUpIdleEventConnections() - CleanUpIdleEventConnections  started
25729 64cc 04/27 23:39:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [103.85 ms], Avg Wait Time [90.00 us]
25729 64cc 04/27 23:39:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [267.00 us], Avg Wait Time [60.00 us]
25729 64cc 04/27 23:39:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [356.67 us], Avg Wait Time [72.33 us]
25729 64cc 04/27 23:39:59 ### TPool [N/A]. Ser# [1] Tot [5], Pend [0], Comp [5], Max Par [5], Avg Work Time [628.40 us], Avg Wait Time [94.40 us]
25729 3f87 04/27 23:40:00 --- IndexCacheMaintenance() - Index cache for client [BPOBRTIAS136] is using 1 MB. Location is [/opt/commvault/MediaAgent/IndexCache].
25729 41e4 04/27 23:43:25 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 41e5 04/27 23:43:25 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 4253 04/27 23:44:27 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=BPOTSMIAS084. Remote port request error.
25729 64cc 04/27 23:44:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [106.02 ms], Avg Wait Time [52.00 us]
25729 64cc 04/27 23:44:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [265.00 us], Avg Wait Time [44.00 us]
25729 64cc 04/27 23:44:59 ### TPool [N/A]. Ser# [0] Tot [5], Pend [0], Comp [5], Max Par [1], Avg Work Time [3.50 ms], Avg Wait Time [55.60 us]
25729 64cc 04/27 23:44:59 ### TPool [N/A]. Ser# [1] Tot [9], Pend [0], Comp [9], Max Par [5], Avg Work Time [30.99 ms], Avg Wait Time [136.33 us]
25729 446a 04/27 23:48:26 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 446b 04/27 23:48:26 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 23:49:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [104.50 ms], Avg Wait Time [50.00 us]
25729 64cc 04/27 23:49:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [249.00 us], Avg Wait Time [53.00 us]
25729 64cc 04/27 23:49:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [337.33 us], Avg Wait Time [44.67 us]
25729 64cc 04/27 23:49:59 ### TPool [N/A]. Ser# [1] Tot [6], Pend [0], Comp [6], Max Par [6], Avg Work Time [963.83 us], Avg Wait Time [130.17 us]
25729 46f4 04/27 23:53:26 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 46f5 04/27 23:53:27 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/27 23:54:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [104.30 ms], Avg Wait Time [60.00 us]
25729 64cc 04/27 23:54:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [232.00 us], Avg Wait Time [60.00 us]
25729 64cc 04/27 23:54:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [369.33 us], Avg Wait Time [61.00 us]
25729 64cc 04/27 23:54:59 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [4], Avg Work Time [754.75 us], Avg Wait Time [127.75 us]
25729 49d4 04/27 23:58:27 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 49d5 04/27 23:58:27 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 4a9a 04/27 23:59:59 --- IndexCacheMaintenance() - Index cache for client [BPOBRTIAS136] is using 1 MB. Location is [/opt/commvault/MediaAgent/IndexCache].
25729 4a9e 04/27 23:59:59 --- CCVDSpaceCheck::CleanupIdleEventConnections() - Invoking CleanUp Idle Event Connections.
25729 4a9e 04/27 23:59:59 ### periodicallyCleanUpIdleEventConnections() - CleanUpIdleEventConnections  started
25729 64cc 04/27 23:59:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [104.52 ms], Avg Wait Time [38.00 us]
25729 64cc 04/27 23:59:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [255.00 us], Avg Wait Time [46.00 us]
25729 64cc 04/27 23:59:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [351.33 us], Avg Wait Time [53.33 us]
25729 64cc 04/27 23:59:59 ### TPool [N/A]. Ser# [1] Tot [5], Pend [0], Comp [5], Max Par [5], Avg Work Time [47.96 ms], Avg Wait Time [153.80 us]
25729 4cbf 04/28 00:03:34 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 4cc4 04/28 00:03:39 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 4d44 04/28 00:04:59 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=BPOTSMIAS084. Remote port request error.
25729 64cc 04/28 00:04:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [105.25 ms], Avg Wait Time [59.00 us]
25729 64cc 04/28 00:04:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [248.00 us], Avg Wait Time [55.00 us]
25729 64cc 04/28 00:04:59 ### TPool [N/A]. Ser# [0] Tot [5], Pend [0], Comp [5], Max Par [1], Avg Work Time [3.47 ms], Avg Wait Time [43.80 us]
25729 64cc 04/28 00:04:59 ### TPool [N/A]. Ser# [1] Tot [5], Pend [0], Comp [5], Max Par [5], Avg Work Time [582.60 us], Avg Wait Time [175.60 us]
25729 4f54 04/28 00:08:44 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 4f5a 04/28 00:08:50 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/28 00:09:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [103.57 ms], Avg Wait Time [57.00 us]
25729 64cc 04/28 00:09:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [238.00 us], Avg Wait Time [43.00 us]
25729 64cc 04/28 00:09:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [336.67 us], Avg Wait Time [42.67 us]
25729 64cc 04/28 00:09:59 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [4], Avg Work Time [570.50 us], Avg Wait Time [87.50 us]
25729 5244 04/28 00:13:50 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 5245 04/28 00:13:50 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 64cc 04/28 00:14:59 ### TPool [JobControlCVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [128.25 ms], Avg Wait Time [49.00 us]
25729 64cc 04/28 00:14:59 ### TPool [JobControlCVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [266.00 us], Avg Wait Time [66.00 us]
25729 64cc 04/28 00:14:59 ### TPool [N/A]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [296.00 us], Avg Wait Time [77.33 us]
25729 64cc 04/28 00:14:59 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [4], Avg Work Time [707.50 us], Avg Wait Time [129.00 us]
25729 54c2 04/28 00:18:51 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
25729 54c3 04/28 00:18:51 ### [CVipcD] ERROR:   ** CVD_CVSESSION_ERROR: RemoteHost=10.221.242.188: Remote execution failed.
Looks like the executable can;t be found:
Can you confirm what is installed on this client?  Might just be the basic client setup and not the full install.
  • April 29, 2022
@Jose Ricardo , to confirm, you didn’t have the agent installed, but once you installed it you now get the error “Decrease Data size by 10 percent”?
Can you share a screenshot of what you are seeing now?
