Synthetic backup Queue
  • November 28, 2022
  • 291 views
Forum|alt.badge.img+5
The Incremental backup runs log over the weekend causing the Synthetic backup to fail to start.  How do I set the Synthetic backup to queue until the incremental backup completes?
Thank you.
Best answer by Jos Meijer
You can queue jobs automatically when jobs are running via these settings:
https://documentation.commvault.com/2022e/expert/6308_queuing_jobs.html
Quote:
Control Panel Options
From the CommCell Console ribbon, click the Home tab, and then click Control Panel.
Under the Data section, click Job Management.
The Job Management dialog box appears.
On the General tab, select the queuing options:
To queue jobs if they conflict with other currently running jobs, select the Queue jobs if other conflicting jobs are active check box.
For example, jobs are queued if multiple backup operations are running for the same subclient.
To queue jobs if the activity control for the job type is disabled, select the Queue Jobs if activity is disabled check box.
To queue scheduled jobs, select the Queue Scheduled Jobs check box.
Scheduled jobs will start in the Job Controller in a queued state at their scheduled time. Manually resume these jobs, or clear the Queue Scheduled Jobs check box to resume the scheduled jobs automatically.
Tip: Select this option during maintenance periods.
Client Level Option
From the CommCell Console ribbon, right-click the client, and then click Properties.
Click Advanced.
To queue jobs if they conflict with other currently running jobs, on the Job Configuration tab, select Queue jobs if other conflicting jobs are active.
Job Level Option
From the CommCell Browser, go to Client Computers > Client > File System > defaultBackupSet.
Right-click a subclient, and click Backup.
The Backup Options for Subclient dialog box appears.
Click Advanced.
The Advanced Backup Options dialog box appears.
To queue jobs if they conflict with other currently running jobs, on the Startup tab, select Queue if other conflicting jobs are active check box.
Schedule Level Option
From the CommCell Browser, go to Policies > Schedule Policies.
From the Schedule Policies pane on the right, right-click a schedule policy, and click Edit.
In the Tasks section, select a schedule task, and then click Edit.
The Backup Task Options dialog box appears.
On the Backup Options tab, click Advanced.
The Advanced Backup Options tab appears.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • November 28, 2022
Client Level Option
Click Advanced.
Job Level Option
Click Advanced.
  • November 28, 2022
Thank you, Jos for a quick response.  I will try the setting now.
  • November 28, 2022
One last question.  The client that is having the issue is a virtual machine.   The VSA host is the client.  At what level should I make the setting?.  The virtual machine in question is in its own subclient.
Thanks.
Jos Meijer
  • November 28, 2022
@Yolanda For VM centric or system wide application it is probably best to use the control panel option, this will allow you to solve this issue for all scenario's.
https://documentation.commvault.com/2022e/essential/126566_jobs_and_job_control_for_vm_centric_operations.html
If you only want to manage VM admin jobs in this manner you might be able to use the client option.
If you want to only apply it on this specific subclient then you might be able to use this by assigning a schedule only for this subclient and set it in the advanced schedule options. Don't know if you use plans, if this is the case then a schedule specific for this subclient can be the less optimal choice.
But the more I think about it whilst writing this, I think the control panel method probably is the only way due to the VM centric setup of the backup. VM specific jobs being generated by the VM admin jobs. These VM specific jobs are related to the VM Instance and are not related to the hypervisor (client) level like the VM admin job.
You will need to test the other two options if you prefer them.
