two factor authentication for domain users
  • November 16, 2023
  • 339 views
I have enabled two factor authentication for commvault specific group in which both domain user and local user are member of , two factor authentication is not working for domain users , is there anyway to make it work
Best answer by Nutan Pawar G
Hi @Ajal
Two factor authentication will not be honored for domain accounts when SSO is enabled.
If you configured the CommCell to allow domain users to log on using Single Sign On (SSO), then Two-Factor Authentication will not take effect on the domain users. We recommend you disable SSO for the respective domain controller.
https://documentation.commvault.com/2023e/expert/7907_enabling_two_factor_authentication_at_commcell_level_in_commcell_console_administrator.html
Forum|alt.badge.img+8
  • November 16, 2023
Hi @Ajal
  • November 18, 2023
I was wondering if we can enable sso only for some user group a in domain
Scott Moseman
Forum|alt.badge.img+23
It’s a setting on a domain, not a user group, so probably not.
Scott
  • December 21, 2023
If you are using two factor to login to the OS and single sign-on for Commvault that should be considered the same as two factor for Commvault.  That’s the way my cyber team views it.
