any how i can set a limit Auxiliary copy jobs, once fist 5 jobs get copied then only next copy job should start. Using stand alone tape library
  • 17 August 2021
  • 157 views
Badge
lets say there are 1000 jobs needs to move on tape, i want to take the secondary copy of jobs on date wise it should not pic random jobs for aux copy.
Best answer by Mike Struening RETIRED 17 August 2021, 15:29
@Rajesh Kumar , it is likely picking jobs based on stream usage on the Primary side.  Let me check internally if we can alter this behavior.
Here you go:
https://documentation.commvault.com/commvault/v11/article?p=11506.htm
You can change the Priority of what the Aux Copy selects.
