Error Code : Error Code: [62:2855] Description: Error occurred in Disk Media
  • October 14, 2022
  • 7 replies
  • 1431 views
Hi ,Please help me whare is the problem , & how can I solve?
Problem:
Error Code: [62:2855] Description: Error occurred in Disk Media, Path [Test_cat\UE3QA4_10.14.2022_15.56\CV_MAGNETIC\V_1] [-1451 OSCLT_ERR_MAXIMUM_DEVICE_LOCKS]. For more help, please call your vendor's support hotline. Source: CDBL-CS-MA, Process: cv
Hyder
Forum|alt.badge.img+8
  • October 17, 2022
Have you tried looking on your Storage end, any issues?
  1. OS event logs check there at time of job failure also
  2. Feels like something on the backend preventing writes to the disk
are you on 11.28?
I have solved the problem. It is the issue on StoreOnce .
Glad to hear you fixed it, @Shaikh Abu Faisal !
Can you share what the detailed cause and fix were?  I can then mark your reply as the Best Answer.
  • December 13, 2022
Hi Shaikh,
What exactly was the problem with the StoreOnce?  We’re seeing a similar issue.
  • August 30, 2023
Hi, All
i know this was last updated a while ago but does anyone have more details on what the problem was? we are seeing the same issue so any insight into the cause would be useful
Thanks in advance
FeRox
Novice
  • December 21, 2023
Hi, could you please share the solution to this error? Thanks
  • July 13, 2024
Can you share what the detailed cause and fix were? thanks
