HyperscaleX DNS requirement
  • Aug 31, 2023 9:21 AM UTC
  • 125 views
Hi Good Day!
I’m planning to deploy new HSX servers. I have a question about the DNS record requirement. Pls help.
Environment detail:
Bond1
VLAN1.bond1 (CS-Registration)  -→ This will be used for connecting to Commserve and VMware backup, DNS, and MGMT.
VLAN2.bond1 (Data Protection)-→ This will be used to backup Agent-based backup.
Bond2 -→ This is for the Storage Pool. DNS record not required.
DNS record planning to create for the bond1 interfaces.
VLAN1.bond1: hsxcsreg01.smaple.com , hsxcsreg02.smaple.com, hsxcsreg03.smaple.com
VLAN2.bond1:  hsxdp01.sample.com, hsxdp02.sample.com & hsxdp03.sample.com   ? Do I need to create a DNS record for the Agent-based backup sub-interface? In this context, I doubt I can have a DNS entry for a sub-interface other than the CS registration.  Please help.
Best answer by R Anwar
Hi @Comtech
DNS entry is needed for hostname which should be used for CS registration. You can add entry for VLAN2.bond1 if needed but it will not be checked during deployment.
R Anwar
  • Aug 31, 2023 11:46 AM UTC
Hi @Comtech
  • Aug 31, 2023 12:47 PM UTC
Hi Anwar, Thanks for your reply. I will update you after deployment
Forum|alt.badge.img+9
  • Certified Expert
  • Feb 29, 2024 9:32 AM UTC
Did it work with DNS only for the mgmt-network? I have a similar situation but docs clearly says that DNS is required for both management and DP network.
“DNS entries are only required for the data protection network and the optional 1GbE management network. Storage pool network does not need DNS entries.”
https://documentation.commvault.com/2024/expert/setting_up_dns_for_hyperscale_x_reference_architecture_setup.html
  • Apr 17, 2024 10:47 AM UTC
@R Anwar
Hi Anwar, could you please confirm if DNS entry is mandatory for Data protection network or not ?
@Comtech
was your deployment successful without DNS record for DP interface ?
