Tape Storage for Secondary Copies
  • Apr 11, 2024 6:51 PM UTC
  • 45 views
Forum|alt.badge.img+2
Where can we find the correct number of tape storage used, if its on our Commserv, Command Center, or Webconsole? Thanks!
  • Apr 11, 2024 8:09 PM UTC
@DBA ,
You can try running the Storage Information report in the commcell console. That should give you the information you are looking for.
Edward J Holowienka
  • Apr 12, 2024 8:24 AM UTC
Thanks Edward. I will give that a try
