Where can we find the correct number of tape storage used, if its on our Commserv, Command Center, or Webconsole? Thanks!
You can try running the Storage Information report in the commcell console. That should give you the information you are looking for.
Edward J Holowienka
Thanks Edward. I will give that a try
