VM's Backup Issue
  • 24 November 2021
  • 10 replies
  • 2676 views
Hello Commvaunt Community,
I need your opinion and support regarding the backup problem for two virtual machines.
The client claims that after updating the environment to version 11.25.6, he began to observe a performance problem for one VM and the other cannot be backed up.
I went down to the logs and for the task, it contains several VMs (but the problem is with one, the task takes 3 days) I found entries that are looped but I do not know what they can mean.
@MediaAgent6 - VixDiskLib.log
34680 6878 11/22 10:57:41 3185939 VDDK_PhoneHome: VddkVacWriteLastMember : Empty field to serialize for key fail_function at line 271.
34680 6878 11/22 10:57:42 3185939 VDDK_PhoneHome: Curl perform failed in VddkVacCurlHttpsPost with error code 7 at 1780.
34680 6878 11/22 10:57:45 3185939 VDDK_PhoneHome: VddkVacPushData : Failed to post data to VC/PH at line 1719.
@MediaAgent6 - vsbkp.log
34680 67b0  11/23 21:03:28 3185939 CVmdkVcb4ExtentReader::ReadBlockFromReadAheadCache() - Delay while looking for block [144745]
34680 3b68  11/23 21:03:34 3185939 VSBkpController::MonitorProcesses() - Detected that other 5 vsbkp processes now have 3 streams running
34680 8af8  11/23 21:03:43 3185939 VSBkpDatastoreMonitor::ReportDatastore() - Datastore [ESX-DMZ-APP-PROD-DS04] [821,008,793,600] bytes free [12.45%]  Update Interval [120] seconds  [1] VMs
34680 67b0  11/23 21:03:43 3185939 CVmdkVcb4ExtentReader::ReadBlockFromReadAheadCache() - Delay while looking for block [144745]
34680 3b68  11/23 21:03:44 3185939 VSBkpController::MonitorProcesses() - Detected that other 6 vsbkp processes now have 4 streams running
34680 3b68  11/23 21:03:54 3185939 VSBkpController::MonitorProcesses() - Detected that other 6 vsbkp processes now have 5 streams running
34680 67b0  11/23 21:03:58 3185939 CVmdkVcb4ExtentReader::ReadBlockFromReadAheadCache() - Delay while looking for block [144745]
34680 3b68  11/23 21:04:04 3185939 VSBkpController::MonitorProcesses() - Detected that other 6 vsbkp processes now have 11 streams running
Searching for available articles but they didn't get me on anything interesting.
Do you have any idea what could be causing the problem? If not, it escalates to Commvault support.
Thanks&Regards,
Kamil
Best answer by Kamil 17 January 2022, 08:42
Something bad happened with the attachments, I added 6 of them, and over 100 sent them. For me, they still load, so if someone can delete them then I will be grateful.
Badge +14
Hi @Kamil ,
Are you able to share a bit more of the vsbkp.log here at all?
-The only info I can see is that we stated 3 times “Delay while looking for block [144745]”
Also, is this Job using SAN transport for the VM Backups?
When looing at the logs you can filter for the “Stat-” counter which can show the performance of the Read/Pipeline operations here.
At the end of a Job you will see counters with “Name [Head ]” for Network, Deduplication and Compression. - When looking at those, look for a high “Procsng Time”.
Michael
Badge +14
HI @Kamil
Is this happening for a single Datastore/ESX?
Which Transport Mode is that Backup using?
Would it be possible to svmotion one VM and run a Backup?
Let us know
Sebastien Merluzzi
Hello @MichaelCapon @Sebastien Merluzzi
I will add again the screenshots that I tried to send yesterday. There is a little more information on them, in the .zip package I send some logs that contain information for the problematic job (JobID: 3185939). They repeat the logs I pasted in the previous message, but maybe I missed something.
The screenshots show that there is a problem with the two vms at the top. The rest of the vms is working fine.
If I can ask for your help, I will be extremely grateful
Kamil
Badge +14
Thanks @Kamil ,
I can see media5 and media6 have SAN access and that’s the method being used for this Job.
-As per Sebastien’s comment above, Would it be possible to svmotion that VM and run another Backup?
Can you confirm what version the Client upgraded from please?
Do you have any earlier vsbkp logs from media6 at all? - Also is the vsbkp PID 34680 still running on media6?
Michael
Could you please let me know if the "svmotion" that Sebastien mentioned refers to this Commvault documentation article?
VMW0067: Change tracking for Virtual Machine [VMservername] has reported an error (VMware)
https://documentation.commvault.com/11.24/expert/32675_vmw0067_change_tracking_for_virtual_machine_vmservername_has_reported_error_vmware.html
Is the procedure good and that is what we should do now?
"Can you confirm what version the Client upgraded from please?" -
The client does not know if this is the direct cause, but said "There was a problem, probably after some update, that some virtual machines do not want to back up. Once, when I had such a problem, it was enough to remove the speed on the media agent."
He is unable to pinpoint after which update the problem started to occur, but has recently been upgrading to SP25.
"Do you have any earlier vsbkp logs from MediaAgent6 at all? - Also is the vsbkp PID 34680 still running on MediaAgent6?" - In the .zip package I am sending all vsbkp.log logs from MediaAgent6 that I have.
Thanks&Regards,
Kamil
Can I ask you for help with the latest message?
Kamil
Badge +14
HI @Kamil
Storage vMotion is a VMWare Operation
https://docs.vmware.com/en/VMware-vSphere/7.0/com.vmware.vsphere.vcenterhost.doc/GUID-AB266895-BAA4-4BF3-894E-47F99DC7B77F.html
Sebastien Merluzzi
Hello Commvault Community :)
Due to the lack of a client update, the thread has been closed. Unfortunately, I haven’t information on what the matter with the described problem looked like.
Maybe someday someone will find this thread useful for troubleshooting :)
Kamil
If anyone does, respond here, or create a new thread referencing this one!
