Hi All,
I tried to move 330 client with file system agent from one plan to another one associated with another gridstor.
i tried not to do this manually, i have found the REST API PUT plan clients Commvault Rest API - Public that can update associations for one client.
it is possible to use this API for a computer group ?
Kind regards,
Christophe
Hi @christophe !  Great question.  I’m not seeing it listed anywhere, so it’s either not listed, or we need a CMR to have the requested option reviewed.
I’m going to engage our dev team for feedback.
HI Mike,
we found another way to move several agents from one plan to another plan.
in the command center it’s possible to select all the clients (select the first in the list and at the end of the list shift + select) and change the associated plan to the new one.
regards,
Good to know and hear!
Let me know if we should mark your reply as the Best Answer :nerd:
