cvpysdk - Error connecting to Commcell
  • 15 August 2023
  • 99 views
Badge +1
I am trying to to explorer automating our Commcell environment. Unfortunately I encountered and error connecting to commcell. I would like to inquiry the error when connecting to commserve using cvpysdk python library. Below is the error.
Error when connecting to commserv using hostname. but i can ping the hostname from the server.
If something is blocking, is there a required port to open to be able to connect successfully?
Badge +10
@ras
>>Use the Python SDK to run Commvault operations in your CommCell environment. The Python SDK requires an installation of the Web Console.​
Step 1: Install the Python SDK​
​Step 2: Install the Python Software​
​Windows and UNIX​
​If you installed the Python SDK on a Windows computer or a UNIX computer, no action is required. Python 3.6 is automatically installed along with the Python SDK.​
On a Windows computer, the installation location is C:\Program Files\Python36. On a UNIX computer, the software is packaged inside the Commvault installation directory: %INSTALL_PATH%/python/bin/python3 (for example: /opt/commvault/python/bin/python3).​
Step:3 Establish a Connection​
>>Applies to: Windows and UNIX clients​
​Import the Commcell class and log on to the CommCell environment. The following is the Python commandlet for establishing a connection:​
>>> from cvpysdk.commcell import Commcell​
>>> commcell = Commcell(webconsole_hostname, commcell_username, commcell_password) ​
​where:​
webconsole_hostname is the host name and port number for the Web Console.​
commcell_username is the user name used to log on to the CommCell environment.​
commcell_password is the user password in plain text. If you do not provide the password in the command, you are prompted to enter the password at run time.​
​Step 4: Where to Go From Here​
​Run Commvault operations through the Python SDK or incorporate the Commvault Python commands into scripts or other code.
For sample you can follow the below DOC:
https://documentation.commvault.com/11.24/expert/45532_samples_for_developer_sdk_for_python.html
DOCs:
https://github.com/Commvault/cvpysdk​
​https://commvault.github.io/cvpysdk/cvpysdk/index.html​
​https://documentation.commvault.com/11.24/expert/1961_preinstallation_checklist_for_developer_sdk_python_on_windows.html​
https://documentation.commvault.com/11.24/expert/45526_getting_started_with_developer_sdk_for_python.html​
Badge +1
Hi Navneet,
Thanks for your time. What i did is the same from what you have provided below and that error I encountered is not able to connect to Commcell when running the python lines the same with you provided.
Hoping you if you could check further my concern.
Badge +10
@ras
We need to review the configuration and logs. You can raise a support case to check this.
