Hello All,
Our Transaction log backup get pending sometimes due to broken chain, then IT converts itself to the FULL backup and It effects our systems during day. Is there a way to kill or suspend job when  transaction log backup Converts to FULL? or is there a way kill/suspend when backup job gets pending?
@ETO ,
You can modify the Job Management settings
There you can select kill the job if it is running over sometime:
Sebastien
Hello @Sebastien Merluzzi
I want to do that for a sepific client , not for all is it posible?
@ETO ,
That is not possible.
thanks for answer,
Is there any workaorund? Because when t-log backup converts itself to Full , our systems are beeing effected.
@ETO ,
You can log a case with Support and we will check.
HelloüI have log a case
Case 240124-489
