Is there an easy way to unlock a workflow?
  • 15 March 2024
  • 30 views
Userlevel 2
Badge +10
Every once in a while my Java session will crash and leave a workflow “locked”
By me, and it won’t allow me to make modifications. I know that restarting the workflow services will unlock it, but there is a way that doesnt require cycling services?
Best answer by Scott Moseman 19 March 2024, 21:02
Userlevel 2
Badge +8
Hi @clecky ,
We will have to fix Java session crashs, can you please create a incident and share logs to investigate this.
Suleman
Userlevel 2
Badge +10
There isn’t anything wrong with Java, I am working from an AVD so it’s prone to networking hiccups.
Most apps are fine, but the Java sessions appear to be sensitive to it.
Usually I just save the workflow with another name and then delete it later, but I was hoping there was a quick command or something I could run.
Badge +18
Edit workflows in Command Center and see if it’s more resilient? 😀
Scott
