KPI Reporting
  • June 24, 2022
  • 164 views
We have a department that is going to be using Commvault APIs to pull restore job success / failure rates, but we only want them to pull the quarterly test jobs we run. With our old backup system we could name the restore jobs when we ran them, but with Commvault we don’t have that functionality. Anyone have a workaround to this?
Best answer by Mike Struening
@stlouischiefs , sounds like you need an item to filter on to get what you need.
Are these jobs run manually or via a schedule?  You can create a Schedule for this exact purpose, and then initiate that schedule manually.
