Need deleted VMs details from vCenter on Commvault.
  • 15 April 2024
  • 85 views
Badge +6
I need the api that gives the deleted VMs list from the vCenter. As per the document:
https://documentation.commvault.com/v11/essential/rest_api_get_virtual_machines.html
I should get isDeleted in status info as a response but I didn’t see anything like that when I ran the Get VM api:
[redacted]
response:
[redacted]
test VM is already deleted.
I need an api that can mention that the VM is deleted on vCenter. So I could go ahead and delete it from commvault.
Badge +6
I ran a backup for this test client just to see if it registers the deleted VM and then it will show in the api call but nothing showed up.
Userlevel 5
Badge +11
@RandomCustomer ,
The call that you are using is not that same call as you referenced, the call you are using is a newer version which currently does not return the information you are looking for. Please try this url instead and you should be the results you are looking for.
https://win/commandcenter/api/VM
Edward J Holowienka
Badge +6
I deleted one of the test VMs from Vcenter. Now it does not appear in output. Rest of them appear.
I can still see that VM on the commandcenter and commcell console. I created a new testvm for testing and it is now deleted from vCenter. but the output says isDeleted : False.
[redacted]
Badge +6
[redacted]
forCV_tobedeleted no longer exists on the Vcenter. It has been deleted. but it still show isDeleted:False . Expected output is :
forCV_tobedeleted: isDeleted - True
Am I missing something here?
