I would like to know if there is any qcommand/ API to power on the Media agent
Please try the below qcommand and let us know if this helps:
https://documentation.commvault.com/2022e/expert/setMediaAgentProperty.html
I couldn’t find an option specifically to power ON or power Off the media agent
I dont want to change/modify media agent properties, rather an action to be performed,
to power on the media agent and power off without using GUI
We don’t have any qscript to do this. Please raise a case so we can check with our dev team internally.
Hello
There is an API call for it as the cvpysdk has it:
https://github.com/Commvault/cvpysdk/blob/master/cvpysdk/storage.py#L654
Mike
