question Python report "REST API" out put format
  • March 2, 2022
  • 147 views
Juergen
Explorer
I use the REST API to read via Python the protection report (XML).
Now the output of this report describes first the columns and in the next session the records.  I use normally xml.etree.ElementTree, to read xml contend, but for this looks not useful, what is the easiest way to get this formatted output in dict or in a list. sorry i am new in python scripting.
regards Jürgen
Best answer by Juergen
@Mike Struening thanks, for support
In the meanwhile I solved my issue, if anyone has interesting here the code snip:
r = requests.get(<url|>, headers=<headers>)
        result = json.loads(r.text)
        #print(result["records"])
        for line in result["records"]:
            #print(line)
            # remove SLA excluded records
            #print(line[2], line[6], line[7], line[12], line[19])
            lastbackup["number"] = num
            lastbackup["Hostname"] = line[4]
            lastbackup["Client"] = line[5]
            lastbackup["Agent"] = line[6]
            lastbackup["Instance"] = line[8]
            lastbackup["Backupset"] = line[7]
            lastbackup["Subclient"] = line[9]
            lastbackup["JobId"] = line[15]
            lastbackup["Status"] = line[14]
            lastbackup["type"] = line[19]
            num = num + 1
            lastbackuplist.append(lastbackup)
            #print(lastbackup)
            lastbackup = {}
Juergen
Explorer
  • March 2, 2022
Sorry this is a question for a Python forum, not for Commvault, is there a way to remove this topic?
Jürgen
@Juergen , maybe better for a python forum, though why don’t we leave it up and see if anyone can advise?
Tagging in some of our peerrs who have asked python REST API questions and might have ideas!
@Anthony.Hodges , @drPhil , @mhamel
Juergen
Explorer
  • March 4, 2022
            #print(line)
            num = num + 1
            #print(lastbackup)
            lastbackup = {}
