Removing client from subclient (not working) and commands execution log
  • 8 May 2024
  • 14 views
Badge +2
I am trying to remove a client from subclient (PowerShell), and it works in most of cases, however I came across with a strange case when automation just does not work, for no reason (the target client stays in the subclient)
I tried to use both methods I know:
Remove-CVVirtualMachine and qoperation execute
both with “error code: 0” on exit 😐
Also, I would deeply appreciate if anyone share the info under witch module in “process manager > logging” commands execution log can be found
Badge +2
Oki, I found the logs:
qcommand
qscript
qsdk
however deletion still not working
