is it correct that the report “Merge Duplicate VM Clients” shows only duplicated VMs?
Some time ago I was able to see all duplicates:
  • VM - VM
  • VM - FileSystem
Now the report doesn’t show duplicate VM - FileSystem clients, in the console I can see them.
Tested on 11.28.37 / 11.24.69 with the APP from Download.
What would be the way to identify duplicate VM - FileSystem clients?
Merge only by CLI?
Sergej
Good afternoon.  Can you please tell me what Feature Release you were on when you were seeing the now changed behavior.  This report shows duplicate VMs only.
Hi Orazan,
I’m not sure, it was 1 or 2 years ago, maybe SP22.
