RestAPI Get Running VMJobs
  • April 22, 2022
  • 359 views
Hello Team
I was trying to get the running jobs for a specific VM. I have below code but it is returning zero results.
function Get-CVVMJobStatus {
param (
$VMName
$vmGuid = ($Global:CVVMData.vmStatusInfoList | Where-Object name -eq $VMName).strGUID
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add("Accept", "application/json")
$headers.Add("Authtoken", $Global:cvToken)
$URI = "http://xxxx/webconsole/api/v2/vsa/vm/$vmGuid/Jobs?completedJobLookupTime=3600&jobTypeList=backup&showAgedJobs=true&backupLevel=Full,Incremental"
$response = Invoke-RestMethod $URI -Method 'GET' -Headers $headers
$JobsData
return $response
Best answer by Carl Manzi
@AbdulWajid , GET Jobs is for querying the backup history. If you’re looking for jobs that are currently running, I believe you’ll need to use POST Jobs:
https://api.commvault.com/#17736755-e86f-9a27-75c5-6c5e999bec80
Are you getting any errors?
I’m pasting the syntax from the docs for this API:
http://WebConsoleHostName/webconsole/api/v2/vsa/vm/{{vmGuid}}/Jobs?completedJobLookupTime=12960000&jobTypeList=backup&statusList=Completed,Killed&showAgedJobs=true&backupLevel=Full
and the example:
curl --location -g --request GET '{{ServerURL}}/v2/vsa/vm/{{vmGuid}}/Jobs?completedJobLookupTime=12960000&jobTypeList=backup&statusList=Completed,Killed&showAgedJobs=true&backupLevel=Full' \
--header 'Accept: application/json' \
--header 'Authtoken: QSDK token would be auto set after POST Login is called.'
https://api.commvault.com/#c6135933-ef59-46fc-9392-9861875eeb47
  • April 22, 2022
and the example:
No Errors. It displays only Completed or Killed Jobs. Even if I remove statusList filter.
I am looking to trigger bulk backup jobs and get the status of those jobs after submission to check the status on percentageCompleted etc.
@AbdulWajid , I don’t see the statusList in your example text.  Are you saying if you add it, it doesn’t make a difference?
If that’s the case, I would open a support case as it sounds like it isn’t working as expected.
If you can confirm the above and open a case, can you share the incident number here?
  • April 25, 2022
