I want to schedule the FSRestoreValidation workflow for automated restore testings. Because this workflow is designed for interactive queries, it doesn´t work as anticipated.
My tries to modify the workflow wasn´t successful.
Is there and easy way to modify the workflow to use parameters instead of interactions?
Thank you and best regards Christian
Best answer by Chris Sunderland
