SQL Server TempDb
  • November 14, 2023
  • 206 views
Hello, I need to move CV SQL Tempdb to a different drive.
I’ve found in the documentation there is a SQL Server Relocate TempDb workflow, but I’m unable to find it on the CV store.
What I’m doing wrong
Thanks and regards
Scott Moseman
Have you checked to see if you have it installed already?
I don’t have an FR28 to check, but it came with my FR32.
Scott
  • November 14, 2023
Yes, you are right. Just finisched to install the FR32 and the workflow is already installed
Thanks and regards
