Tracking loop progress in workflows
  • March 9, 2022
  • 126 views
christopherlecky
Challenger
Forum|alt.badge.img+16
Is there any way to get the loop index and counter in any of the for loop activities?
I have been setting a counter variable prior to the loop starting and incrementing it at the end of every loop, but surely this already exists.
Also I get wonky results when I allow loops to run multiple processes at once.
Best answer by RMcG
To fetch the current index you can use workflow.getParent().getLoopIndex() in a script activity inside the for loop. Will also work in the onstart and oncomplete scripts on other activities inside the for loop etc.
@RMcG may know
  • March 10, 2022
christopherlecky
Challenger
Excellent.
Safe to assume this of the same for all the for loop? foreachjson? for example?
Thanks.
