Using workflow activity VMutility to cloneVM
  • November 16, 2022
  • 69 views
using the “cloneVM” activity in a workflow fails.
The workflow
Inputs of HttpClient
Inputs of CreateNetwork
“On start script” on the first delay
The inputs for the clone activity
The clone job
The logs:
The error is same if I:
  • Used the vmGUID only (without the vmName)
  • Used the vmName only (without the vmGUID)
  • Tried the vmName or the vmGUID constants not variables
Best answer by Mostafa Amin
The issue is solved by cloning a VM template instead of a VM.
Now, the VM template gets cloned (create a VM) but with no Hard Disk or operating system installed.
Thanks for the post!
Before we take a deeper dive, I noticed something that seemed off.
Is your network name actually ‘netowrk’ or is that a typo?
  • November 17, 2022
@Mike Struening
Yes, My network actual name is “netowrk”
  • November 17, 2022
Appreciate the follow up!  To confirm, is this what you were looking to do (before we mark this as solved)?
  • November 17, 2022
@Mike Struening
Yes, thanks
