Hi
https://documentation.commvault.com/2023e/expert/GetAllRunningJobs.html
I want to filter the output for the qscript to get all running jobs.
Get the list of running jobs (backup, admin, restore) on the clients
Usage
qoperation execscript -sn GetAllRunningJobs
script_name :GetAllRunningJobs
The document doesn’t have much details to it.
by OperationType - backup/ restore
by Client - which has %prd%
or by ClientName - ‘abc001’
Is there a way to achieve this?
where can i get the list of valid options / filters that we can use with qscript. ?
Hi @alligator ,
There is no options to be used, just run this:
You need to qlogin first.
Sebastien
@Sebastien Merluzzi
Thanks for your response
I’m able to run the qscript
but i would like to limit the result from the qscript for restore jobs or to a particular client etc
That’s all the running jobs. No options to filter, you might be able to copy/paste in excel and filter there.
i would want to use this in a workflow
this does work , where -format csv the results are generated in comma separated format
Hence i think there could be some way to filter the output
ok, perfect.
