Hi everyone, I have live sync enabled between two comm cells “Active and Passive”. DB maintenance haven’t run since around 2 years. the workflow is disabled unfortunately.
I need to run the command dbmaintenance -full on the active server. Shall I disable the live sync before running the command? Do I need to run the same command on the passive commcell server as well?
Thanks in advance
