How to disable sapphire SIMPANA 10
  • 13 September 2021
  • 33 views
Badge +13
How to disable sapphire Simpana 10 in my Fujitsu server rx2540 M5
I cant disable by msconfig, dont appear:
Best answer by Mike Struening RETIRED 13 September 2021, 19:26
Badge +13
I renamed the directory
Do you have an old install that won’t go away?  I’m assuming this was an Fujitsu server rx2540 M5 that came with v10 pre-installed?
