How to disable sapphire SIMPANA 10
  • September 13, 2021
  • 60 views
Fernando Souza
Explorer
How to disable sapphire Simpana 10 in my Fujitsu server rx2540 M5
I cant disable by msconfig, dont appear:
Best answer by Mike Struening
Do you have an old install that won’t go away?  I’m assuming this was an Fujitsu server rx2540 M5 that came with v10 pre-installed?
Fernando Souza
Explorer
I renamed the directory
