Inconsistencies between java GUI/Command Center regarding encryption
  • September 30, 2022
  • 120 views
Hi all,
I have reviewed 2 environments showing the same inconsistency, FR24 and FR28/2022E (On screenshots)
On a storage policy that has a snap and a primary copy where encryption is used the following is seen:
Java GUI > Properties on primary copy > Shows encrypted (Taken over from GDDB, as expected)
What I expect to see in command center, when I review my backup copy job > Encryption Enabled: Yes, as we can see in the java GUI.
What it actually shows:
Encryption enabled: Unavailable
When reviewing the snap job (Which does not use dedupe, and we do not encrypt it)
In the command center it shows: Encryption enabled: Yes
In java GUI it shows: Encryption enabled: No (As expected, because we do not encrypt the snaps)
Is this somehow expected behavior, or should we raise a case to dig into this more?
Best answer by Mike Struening
Hi @WR1 and thanks for the thread!
I went right to the best person to ask: the Manager of the team that handles Encryption.
He said this one should definitely be an incident as it might need dev assistance.
Can you create a support case and share the incident number here so I can track its progress?
