Hello @0ber0n
Do you already have a copy within the policy associated to the Private Cloud Library Storage Pool? If so you cannot associate another to it. Only one Copy within a Policy can be associated to a deduplicated Storage Pool.
Thank you,
Collin
hi @Collin Harper
Is there a reason why only one copy can be added ?
Hello @0ber0n
This is a limitation due to the DDB. No two copies within a policy can use the same DDB.
Thank you,
Collin
Hello @Collin Harper,
I see this article is closed, but I have anyway additional question. Limitation is one Storage policy copy per policy and DDB. What if is created Storage policy copy without DDB inside same SP? Can I have multiple SP copies non-deduplicated with multiple retentions?
Reason I am asking is, I need to create additional SP copy1 for mothly backups + retention 1y and SP copy2 for weekly backups + 3months retention. Both need to reside on same Cloud library inside existing SP with DDB.
Thank you.
Hello @lubimkomvolt
Yes you can have whatever retention you’d like on as many copies as you’d like. Deduplication does not affect retention so either way you can use whatever retention you’d like. It might also be worth looking into using Extended Retention.
Extended Retention Rules - https://documentation.commvault.com/2023e/expert/extended_retention_rules.html
Thank you,
Collin
