Hello @Michal Osewski
The documentation only lists 2016 and 2019 because that is all that is listed as supported by HCL
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0086047
Operating Systems
OS |
Windows Server 2016, 2019 (All editions) |
Thank you for your reply.
The customer currently has HCL 12.0.2 version that is why he wants migrate OS from AIX to Windows Server 2022. As you can see from the following documentation there is support for WS2022.
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0101447
Does commvault has plans for such support? If so - when?
Michał
Got it thanks, appears HCL supports 2022 as per an update.
Commvault generally will always support the OS that the application vendor supports, I will confirm on this and update the thread.
Hi @Scott Reynolds
Okay. Please let me know, when you confirm this.Thanks!
I can confirm that we will be certifying Windows 2022 as well as Domino 14.
Once testing is complete documentation will be updated to include these are supported.
Hello @Scott Reynolds
Thank you for the information.
Is an approximate timeframe already known, e.g. in which quarter will certification for WS2022 be introduced?
@Michal Osewski This is actively being worked on and I expect it to be completed by end of this month maybe sooner unless any unexpected events occur. But there is not set date and anything can change.
Do you have some news about certification date?
This has been completed and integration complete for Domino 14 and WIN2022
Domino 14 on Linux/AIX is being completed and Documentation is being updated for everything and will be reflected in FR32-FR36 all at once. Usually,
Successive CV Service Pack versions are released, and then there is no support for Domino 14 with Windows Server 2022.
The customer asks me about it and I don’t know what to answer...
Hello Commvault Community,
Do we have any date when the documentation towards this topic will be updated? Customer would like to have confirmation in the form of an entry in an article in the documentation.
Thanks&Kind Regards,
Kamil
Is there any new information? I can’t see windows server 2022 on list in documentation below.
https://documentation.commvault.com/2024e/expert/hcl_ibm_domino_and_notes_system_requirements.html
Michał
Tip: I tried for several days configure hcl domino backup on one of our customers that runs it on windows server.
The last step i tried was to install the hcl domino package directly on the client after it was registered in gui since i did not get backup to work properly just pusing it out from the comcell. It turned out that during the installation a pop-up window appeared where we needed to specify hcl more info about hcl domino and then it worked.
