System requirements for HCL Domino
  • March 14, 2024
  • 15 replies
  • 562 views
Forum|alt.badge.img+5
The customer would like to change the HCL Domino (AIX 7.2) production operating system to Windows Server 2022.
I see in the documentation that there is support up to a maximum of WS2019.
I would like to enquire if perhaps the manufacturer has not updated the documentation or if indeed WS2022 is not supported.
https://documentation.commvault.com/2022e/expert/notes_database_system_requirements.html
Michał
Hello @Michal Osewski
The documentation only lists 2016 and 2019 because that is all that is listed as supported by HCL
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0086047
Operating Systems
OS
Windows Server 2016, 2019 (All editions)
  • March 18, 2024
Thank you for your reply.
The customer currently has HCL 12.0.2 version that is why he wants migrate OS from AIX to Windows Server 2022. As you can see from the following documentation there is support for WS2022.
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0101447
Does commvault has plans for such support? If so - when?
Michał
Got it thanks, appears HCL supports 2022 as per an update.
Commvault generally will always support the OS that the application vendor supports, I will confirm on this and update the thread.
  • March 22, 2024
Hi @Scott Reynolds
Okay. Please let me know, when you confirm this.Thanks!
I can confirm that we will be certifying Windows 2022 as well as Domino 14.
Once testing is complete documentation will be updated to include these are supported.
  • April 9, 2024
Hello @Scott Reynolds
Thank you for the information.
Is an approximate timeframe already known, e.g. in which quarter will certification for WS2022 be introduced?
@Michal Osewski This is actively being worked on and I expect it to be completed by end of this month maybe sooner unless any unexpected events occur. But there is not set date and anything can change.
  • May 24, 2024
Do you have some news about certification date?
This has been completed and integration complete for Domino 14 and WIN2022
Domino 14 on Linux/AIX is being completed and Documentation is being updated for everything and will be reflected in FR32-FR36 all at once. Usually,
  • June 19, 2024
I don’t see any information about Domino 14 and Win2022 yet.
https://documentation.commvault.com/2024/expert/hcl_ibm_domino_and_notes_system_requirements_03.html
  • August 19, 2024
Successive CV Service Pack versions are released, and then there is no support for Domino 14 with Windows Server 2022.
The customer asks me about it and I don’t know what to answer...
  • September 2, 2024
Hello Commvault Community,
Do we have any date when the documentation towards this topic will be updated? Customer would like to have confirmation in the form of an entry in an article in the documentation.
Thanks&Kind Regards,
Kamil
  • December 17, 2024
Is there any new information? I can’t see windows server 2022 on list in documentation below.
https://documentation.commvault.com/2024e/expert/hcl_ibm_domino_and_notes_system_requirements.html
Michał
  • December 18, 2024
Tip: I tried for several days configure hcl domino backup on one of our customers that runs it on windows server.
The last step i tried was to install the hcl domino package directly on the client after it was registered in gui since i did not get backup to work properly just pusing it out from the comcell. It turned out that during the installation a pop-up window appeared where we needed to specify hcl more info about hcl domino and then it worked.
  • September 5, 2025
Hi ​@Scott Reynolds,
Has the integration been completed? I see that the documentation still hasn't been updated for Windows Server 2022.
