I have an Auxcopy Source (HYperscale-X), destination (Hy7perscale). I have max numbers of readers set and multiple mount paths set on the Copy.
I have thousands of jobs in the Auxcopy, yet only one stream gets allocated.
What am I missing?
What am I missing?
Check:
None of those. What I did notice is that the destination copy was not deduplicated (some one has set this up adhoc), when I repointed destination to same storage with deduplication the number of streams improved.
If destination copy was not deduplicated, did it have combine to stream enabled? If so, it may have been set to 1?
