AWS authentication issues after FR26 upgrade
  • 27 December 2021
  • 8 replies
  • 793 views
Badge +10
  • Commvault Certified Expert
  • 49 replies
My demo CommCell was upgraded to FR26 recently and MA is getting AWS authentication issues ever since.
Version: 11.26.3
Storage: NetApp ONTAP S3
CVMA.log
7040  104c  12/27 15:39:06 #####  [DEVICE_IO]  Message: AWS authentication requires a valid Date or x-amz-date header
7040  2d84  12/27 15:39:06 #####  [DEVICE_IO] GetFileSize() - Error: Error = 44106
CloudFileAccess.log
7040  22f4  12/27 15:43:09 ### [CVMountd] OpenFile() - <bucket>/3672BF_06.01.2021_10.33/CV_MAGNETIC/V_3888/CHUNK_152953/SFILE_CONTAINER.idx, mode = READWRITE, error = Error = 44106
7040  28f0  12/27 15:43:09 ### [CVMountd] OpenFile() - <bucket>/3672BF_06.01.2021_10.33/CV_MAGNETIC/V_3044/CHUNK_121116/SFILE_CONTAINER.idx, mode = READWRITE, error = Error = 44106
CloudActivity.log
7040  25b8  12/27 15:42:59 ### [CVMountd]  Message: AWS authentication requires a valid Date or x-amz-date header
7040  2ab0  12/27 15:42:59 ### [CVMountd] GetFileSize() - Error: Error = 44106
What changed with FR26? I already tried with new access keys and it didn’t help. There is not time difference between MA and S3 server. FR24/25 MAs don’t have such issues.
Thank you.
Best answer by euMike 10 January 2022, 19:30
Badge
It complaining no valid data header. Please set the  debug level 3 for CloudActivity log and rerun the job to get detailed error. Please escalate to Commvault support team  to collect the  log to check this  issue.
Karthik
Badge +10
Hi Karthik,
No option to open support ticket due to NFR license.
I tried downgrading MediaAgent back to FR25 and the issue was resolved immediately. I will wait for aux copy to complete. Then I can upgrade it back to FR26 and collect new logs.
I suspect that FR26 comes with updated/changed date and time classes/JDK or something like that. Can anyone from Commvault confirm this?
Thanks.
@euMike , any luck on the upgrade back to 26?  Tagging @Karthik in case he missed the last reply.
Badge
Thanks Mike.
euMike
No  change in that class.  In our local setup it is working fine,   We need the cloudactivity log with debug level 3 when issue is  happening . From the Commvault Process Manager , under Logging tab, select the CloudActivity log and set the debug level to 3. Once  issue is  reproduced  , please revert back the  changes , once you collect the logs   paste the  error  .
I am not sure what is NFR license restriction to open Ticket .
Karthik
Badge +10
Hi there!
I did some testing.
I tried to create a new cloud library twice - first time with FR25 and then with FR26. Same bucket, service host, credentials.
MA FR26 - failed, date header errors
Host: <s3 service host>
User-Agent: APN/1.0 CVLT/1.1 CVRF/2.0
Accept: */*
x-amz-date: Wed, 05 Jan 2022 18:51:47 GMT
Authorization:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
13200 1728  01/05 19:51:47 ### [CVMountd] == cURL Info: Mark bundle as not supporting multiuse
13200 1728  01/05 19:51:47 ### [CVMountd] <= HTTP/1.1 403 Forbidden
13200 1728  01/05 19:51:47 ### [CVMountd] <= Server: NetApp CSS/9.9.1P5
13200 1728  01/05 19:51:47 ### [CVMountd] <= Date: Wed, 05 Jan 2022 18:51:47 GMT
13200 1728  01/05 19:51:47 ### [CVMountd] <= Connection: Keep-Alive
13200 1728  01/05 19:51:47 ### [CVMountd] <= Content-Length: 158
13200 1728  01/05 19:51:47 ### [CVMountd] <= Content-Type: application/xml
13200 1728  01/05 19:51:47 ### [CVMountd] == cURL Info: Connection #1 to host <s3 service host> left intact
13200 1728  01/05 19:51:47 ### [CVMountd] GET 403 Time:0.019 Size:158 Speed:8117 B/s NAMELOOKUP:0.002 CONNECT:0.013 PRETRANSFER:0.015 STARTTRANSFER:0.015 http://<s3 service host>/<bucket>?delimiter=%2F&prefix=<bucket>%2F
13200 1728  01/05 19:51:47 ### [CVMountd]  Message: AWS authentication requires a valid Date or x-amz-date header
13200 1728  01/05 19:51:47 ### [CVMountd] CVRESTBaseRemoteFile::SetRESTErrorCode() - Error:  Message: AWS authentication requires a valid Date or x-amz-date header
13200 1728  01/05 19:51:47 ### [CVMountd] == cURL Info: Found bundle for host <s3 service host>: 0x1907b9b2f60 [serially]
13200 1728  01/05 19:51:47 ### [CVMountd] == cURL Info: Connection 1 seems to be dead!
13200 1728  01/05 19:51:47 ### [CVMountd] == cURL Info: Closing connection 1
13200 1728  01/05 19:51:47 ### [CVMountd] == cURL Info: Hostname <s3 service host> was found in DNS cache
13200 1728  01/05 19:51:47 ### [CVMountd] == cURL Info:   Trying <s3 service host IP>:80...
13200 1728  01/05 19:51:47 ### [CVMountd] == cURL Info: Connected to <s3 service host> (<s3 service host IP>) port 80 (#2)
13200 1728  01/05 19:51:47 ### [CVMountd] => DELETE /<bucket>/dfaksdhfuq43yAF9834fmabvfjhFDGgv8743rvbfdabuyewbasdfahdDCCZfabdfbchasd HTTP/1.1
MA FR25 - succeeded
Accept: */*
Content-Length: 0
Content-Type: binary/octet-stream
x-amz-acl: private
x-amz-date: 20220105T191538Z
x-amz-content-sha256: e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855
Authorization:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Expect: 100-continue
10592 262c  01/05 20:15:38 ### [CVMountd] == cURL Info: Mark bundle as not supporting multiuse
10592 262c  01/05 20:15:38 ### [CVMountd] <= HTTP/1.1 100 Continue
10592 262c  01/05 20:15:38 ### [CVMountd] <= HTTP/1.1 200 OK
10592 262c  01/05 20:15:38 ### [CVMountd] <= Server: NetApp CSS/9.9.1P5
10592 262c  01/05 20:15:38 ### [CVMountd] <= Date: Wed, 05 Jan 2022 19:15:38 GMT
10592 262c  01/05 20:15:38 ### [CVMountd] <= x-amz-request-id: 3256912554
10592 262c  01/05 20:15:38 ### [CVMountd] <= Connection: Keep-Alive
10592 262c  01/05 20:15:38 ### [CVMountd] <= Content-Length: 0
10592 262c  01/05 20:15:38 ### [CVMountd] <= Content-Type: text/html
10592 262c  01/05 20:15:38 ### [CVMountd] <= ETag: "d41d8cd98f00b204e9800998ecf8427e"
10592 262c  01/05 20:15:38 ### [CVMountd] == cURL Info: Connection #0 to host <s3 service host> left intact
10592 262c  01/05 20:15:38 ### [CVMountd] PUT 200 Time:0.007 Size:0 Speed:0 B/s NAMELOOKUP:0.001 CONNECT:0.001 PRETRANSFER:0.001 STARTTRANSFER:0.002 http://<s3 service host>/<bucket>/IXPJYX_01.05.2022_19.15/CV_MAGNETIC/_DIRECTORY_HOLDER_
Based on CloudActivity log x-amz-date format has changed with FR26 and ONTAP S3 won’t accept it.
Badge
Thanks euMike.
We have local test account  StorageGRID/11.6.0.   and there it is working . Want to confirm  what is difference in  Server: NetApp CSS/9.9.1P5  ,
We need  following  to trouble shoot further.
  1. Can you please send the current CloudActivity full  log to me at karthik@commvault.com
  2. One more case to  try , please set this Reg key  ncloudAWSV4  to  value  2  at HKEY_LOCAL_MACHINE\SOFTWARE\CommVault Systems\Galaxy\Instance001\MediaAgent  like below and rerun the  job and  let us know it worked or not . Please share the cloud Activity log for this also .
  3.
Badge +10
Hi! StorageGRID (extra logic on top of SANtricity) and FAS/AFF (ONTAP) are two completely different systems.
I tried with an extra reg key but it didn’t work. ONTAP S3 requires signatures v4.
I sent you log file as requested.
I really appreciate your help guys!
Badge +10
Update - the issue was resolved by installing the Diag2063 on MediaAgent. Big thanks to Karthik and the rest of you guys!
