Actually we testing boostfs (Data Domain) with Commvault it’s possible to configure two MA in Grid store with Boost FS ??
View originalActually we testing boostfs (Data Domain) with Commvault it’s possible to configure two MA in Grid store with Boost FS ??
View originalIf you have 2 Media Agents writing to that DD device, then it shouldn’t be an issue.
yes but normally when you configure a library with boostfs you point to a local drive mounted on the media agent.
So i don’t know how you can share a local drive for the same path of the library.
You can probably create a library with 2 mountpath 1 on each media agent but in that case it’s not gridstore
i mean if MA goes down in that case the path will become unavailble so yes backup will continue to the second path. But you can’t restore anymore no ?
