After changing tape librariy, the aux copy job always asks me for the previous media written, can someone help me?
Change Tape Library
Hi
Hi
Hi
“Description: The operation cannot be completed as the media is outside the library.Check streams information for more details
Source: commvault, Process: JobManager”
Is the source copy using a tape library or a disk library?
If the source data is on tape, then the necessary tapes should be loaded for the read operation.
Ensure all the necessary source media are loaded so that the auxiliary copy operation will start to progress.
Anymore, I think I solved it by disabling the combine data stream.
I'll update you with the next schedules and thank you for the suggestion
Same error, but the job is 99%:
Error Code: [62:75]
[DrivePool(cacv01)57], Media[000080L6]: The operation cannot be completed as the media is outside the library. Advice: Please import the media into library and try again.
Error Code: [62:75]
