DDB creation "The specified path is already in use"
  • March 26, 2021
  • 163 views
I’ve needed to delete - create again the DDB and I need to use same partition paths as they were used before (disk was formatted). Currently I cannot create a DDB as I have message:
“The specified mount path os already in use”
Well I know that it’s described here:
http://kb.commvault.com/DD0051
But do you know somebody if there is way to force cleanup and do not wait 24h ? The data aging is not doing the trick.
Best answer by Prasad Nara
We allow using same path in 11.22 or higher version.
@Tomas , I don’t know a way to force it, but you could create it now in another folder, then move it to your desired folder later.
That might help and avoid the delay.
  • March 26, 2021
