How to backup VMware vvol disks
  • Dec 4, 2023 7:26 PM UTC
  • 319 views
I need to figure out how to setup a subclient to backup vvol disks on our VMware environment. When I google this, it brings up everything but vvol and I am havng difficulty finding it in Commvault dicumentation. Our level is 11.28.83. Is this just the same as setting up any subclient? Or does it need a plugin to work? Any help yoou guys can give me on this is appreciated.
Hello @sekreber
The following goes over vVols and how to setup them up in Commvault:
https://documentation.commvault.com/2023e/expert/62400_intellisnap_protection_for_vms_on_vvol_or_vsanvxrail_datastores.html
please advise if this answers your questions.
Kind regards
Albert Williams
Hello @sekreber
Kind regards
Albert Williams
  • Dec 5, 2023 2:44 PM UTC
Thank you Albert Williams, this is exactly what I needed. Thanks to you, the backus are running successfully.
