Hi
I have full backup daily.
Basic retention is set to 7 day 1 cycle.
I need to extend retention only for first Saturday of each month to 90 day.
How to specific the first Saturday?
Hi
Hello
I don't think you can achieve the first Sat of every month with the context of you running daily fulls.
If you change your schedule to be Incremental backups through the week and fulls run on Saturday then you can do extended retention for the first full of the month.
Kind regards
Albert Williams
Hi Albert
Thanks for your suggestion.
Hello
If your question is answered please mark the thread as so please.
Kind regards
Albert Williams
While it may not be possible at the Storage Policy Copy level, you could use Schedule Policies to meet your requirement by creating a First Saturday of the Month schedule, and using the Advanced > Media > Job Retention options to extend retention.
Kind regards
Albert Williams
Hi
This solution very helpful. Thank you
