Leveraging SnapLock on a CIFS Disk Library
  • 15 June 2023
  • 337 views
Badge +8
Hi all,
NetApp has mentioned to a customer that Commvault can leverage NetApp’s SnapLock feature on a FAS CIFS Disk Library to provide immutablility of backup data.
I found the following 2 articles regarding this:
https://documentation.commvault.com/2023/expert/146623_configuring_worm_storage_mode_on_disk_libraries.html
https://documentation.commvault.com/2023/essential/155629_enabling_worm_storage_and_retention_for_disk_storage.html
These docs seem to be about two different features? One is enabled using a workflow and mentions DDB sealing. The other is enabled using a slider in Command Center, and mentions nothing about DDB sealing.
Can anyone tell me the difference between the two (and what they do exactly)?
And which feature should I best use to leverage SnapLock on a FAS CIFS Disk Library to provide immutablility of backup data?
Badge +8
Anyone?
