Move disk library to another MA
  • Nov 8, 2023 3:43 PM UTC
  • 332 views
Hi all,
I have my current MA which has iSCI QNAP storage disks. I want to move all data to a new MA and start using this one.
How is suposed to do this about storage disks? I just want to disconnect iscsi from old and connect to the new one but I dont know how to do it at Commvault.
Do I must use “share mountpath” or “move mountpath”? (no need to copy data, just present the disks at the new MA and start using it)
Im a bit confused about that. Im using Comvault 11.28
Thanks in advance
Joan
Best answer by Scott H
Hi Joan,
Thanks for reaching out for assistance.
To do this you can present the Storage on the New MA and within the Properties of the Mount Path on the Disk Library you can add a new Path for the new MA and then remove the old path.
Steps for adding MP Sharing:
https://documentation.commvault.com/2023e/expert/9374_sharing_mount_path.html
If this dedupe data you will also need to move your DDB to the new MA:
https://documentation.commvault.com/2023e/expert/12576_moving_deduplication_database.html
Please let me know if you have further questions.
Kind regards,
Scott Henderson
Media Management - Technical Team Lead (APAC)
Scott H
  • Nov 16, 2023 12:14 AM UTC
Hi Joan,
Kind regards,
Scott Henderson
  • Nov 21, 2023 11:25 AM UTC
Hi Joan,
Kind regards,
Scott Henderson
Dear Scott,
Thanks for you answer. I did the move and everything seems to be OK.
Joan
