s3 worm and infinite retention
  • 25 September 2023
  • 39 views
Badge +2
Hello is it possible to enable worm on a s3 bucket with infinite retention?
If we want to worm only for 30 days with infinite retention what is the best way?
  • Just create a copy with infinite retention and worm enabled on  it
  • Create a copy of 30 days with worm and add extended retention
thanks in advance
Badge +10
@Aglidic
Please follow the below DOC for your requirement:
https://documentation.commvault.com/2022e/expert/9251_configuring_worm_storage_mode_on_cloud_storage.html
Badge +2
yes i know.
For deduplication enabled storage pools, the seal frequency of the deduplication database (DDB) is set to the same number of days as retention set in the storage policy copies of selected storage pool, with a maximum of 365 days. For example, if the retention is set for 60 days in the dependant copies of the storage pool, the seal frequency for the DDB is also set to 60 days. For retention higher than 365 days, the seal frequency is set to 365 days
So with infinite retention i have to go with extended retention.
Badge +10
@Aglidic
Please check the below link. Hope this will help you:
